Blackberrys
Blackberrys
Mensaje  Admin el Jue Feb 12, 2009 4:41 pm
Blackberry Curve Unlock Instructions
1. You must have an original SIM card in your phone to complete these steps (can be active or inactive with the network)
2. Goto Setting Menu
3. Goto Options Menu
4. Go to advanced options
5. Go to sim card
6. Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
7. Type MEP[Alt + 2] ( M E P, Then type Alt key, then 2 )
8. You should be presented with a prompt "Enter Network MEP Code". Type in the 16 or 8 digit unlock code
9. Your phone is now unlocked
Blackberry Unlock Code Instructions for 9500 Storm:
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keybord
7. Enter mepd (you will not be able to see the typed info)
8. Enter mep2
9. Now it will say enter network mep code
Blackberry 8700 Unlock Code Instructions:
Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked.
Blackberry 8800 Unlock Code Instructions:
***** You must have a SIM card in your phone to complete these steps ( Can be active or inactive ) *****
1 - Go to settings menu => and then Options
2 - Select Advanced options => and then Sim card
3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from cellunlockcode.com and press in the track wheel / jog dial to confirm
6 - Your phone is now unlocked
Blackberry 8100 Unlock Code Instructions:
1 - Go to Options Menu => Advanced Options
2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
4 - Enter the unlock code.
