Otros Modelos Blackberry
Mensaje  Admin el Jue Feb 12, 2009 4:42 pm
Blackberry Unlock Code Instructions (all other models):
1 - Using the menu go to Settings Menu -> SIM card pressselect.
2 - While holding the SHIFT key, type mepd
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type mep2.
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Blackberry Unlock Code Instructions for 7100 & 7130 Models:
1. On the Home screen, click the Tools icon. The Options screen appears.
2. In the tools screen, select the Settings icon.
3. Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4. Type ‘mepp2' to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2) ( you will not see text appear on screen while typing )
5. Input the SIM Unlock code
6. Press in the jog dial once
Blackberry Unlock Code Instructions for 5xxx, 6xxx, 7xxx Models:
Supported models: 5xxx, 6xxx, 7xxx ( Except for 7100 )
1. go to options
2 scroll to SIM CARD then press jog dial in once to select it
3. Type MEPD (not case sensitive) ( you will not see text appear on screen while typing )
4. Does it say Network active? if so your phone is locked
5. Press and hold the alt key (half moon looking key on the lower left side)
6. as you are holding the alt key type in MEPE (not case sensitive) ( you will not see text appear on screen while typing )
7. type in the unlock code when prompted
8. After entering the code press the jog dial in
9. Your phone is now unlocked
