Nokia Instruciones
Nokia Instruciones
Nokia Unlock Code Instructions for ALL NOKIA MODELS:
READ THESE NOKIA INSTRUCTIONS VERY CAREFULLY. YOU GET 3 TRIES TO ENTER THE CODE, SO IF THERE IS A PROBLEM YOU NEED TO KNOW EXACTLY WHAT TO DO!
-If your Nokia phone gives you a message saying "RESTRICTED", shut down your phone, remove the simcard, power on phone and perform the "CODE ENTRY" instructions below.
-If your phone doesn't say "RESTRICTED", make sure your phone has a simcard from any other provider (other the the one the phone is locked to) and perform the "CODE ENTRY" instructions below.
-If you entered a bad code too many times and get the error "NOT ALLOWED", then your counter is blocked and only a cable method will unlock your phone.
CODE ENTRY INSTRUCTIONS
-The unlock code that must be entered will look something like this: #pw+UNLOCKCODE+1#
In the email you received, you were most likely just sent a code, something like 454545454567715 (every customer has his own special code so yours will be totally different). You must replace that code with the UNLOCKCODE text shown above..so the entire thing to enter into your phone will look like:
#pw+454545454567715+1#
Sometimes we will email you the entire thing so you get #pw+454545454567715+1# but this doesnt happend often.
-Every digit, symbol, number and letter that you see above must be entered without any spaces. Follow the directions below to find put how to get the # p w and +
P appears after pressing 3 times the button ( * )
W appears after pressing 4 times the button ( * )
+ appears after pressing 2 times the button ( * )
- after entering your unlock code the phone should show "SIM Restriction Off". Youg Nokia is now unlocked.
WHAT IF I DIDNT WORK THE FIRST TIME?
First, try these alternate code-entering instructions:
#pw+UNLOCK CODE+7#
so it would look like: #pw+454545454567715+7#
If that doesn't work, contact us and we will recheck the code to make sure the one you receieved is correct.
#pw+UNLOCK CODE+7#
» Fallas Nokia
» Programa nokia
» Diagramas Nokia
» Videos como desarmar nokias
» Falla de Carga Nokia 5300
» Programa nokia
» Diagramas Nokia
