LG como poner el codigo subsidy
Mensaje  Admin el Jue Feb 12, 2009 4:52 pm
LG CU-320 Unlock Code Entry Instructions
1) Power on the Handset.
2) In Idle screen, input the special code "277634#*#".
3)Access the submenu "SIM Test" in Phone Test Mode.
4)Input the special code "2945#*#".
5)Access the submenu "SIM Unlock" which is just activated after the special code
6)Input the 8-digit Unlock code in the "Enter unlock code" input screen.
7)It will be unlocked.
LG U-400 Unlock Code Entry Instructions
1. Insert the Accepted Sim Card.
2. Enter 2945#*88110#.
3. The phone will then prompt 'Unlock sim'. Press OK.
4. The phone will then prompt 'Network Unlock'. Press OK.
5. The phone will then prompt- 'Input Network Control Key'.
Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
6. It should give you the message Success.
7. Come back to the main screen and Enter 2945#*88110#.
8. The phone will then prompt unlock sim. Press OK.
9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
10. Then press OK
LG CU-400 Unlock Code Entry Instructions
1-Insert non-Cingular SIM card
2-Power on the handset
- phone will display "Invalid SmartChip"
3-In Idle screen, enter 159753#*#
- phone will display "Enter NCK, Remaining 5"
4-Enter the 8 digit SIM Unlock code
5-Select "OK"
- the handset is now successfully unlocked
LG CU-500 Unlock Code Entry Instructions
How-To Enter Unlock Codes on LG CU500 mobile phones:
Insert a non-Cingular SIM card into your LG CU 500 and power on your phone. When you get the invalid sim-card message/prompt, enter 159753#*# on your phones keypad. On the next screen enter the unlock code provided than press OK.
*if you have a Cingular/at&t LG CU-500, do the following*
1.Insert non-Cingular SIM card.
2.Power on the handset. Phone will display "Invalid SmartChip"
3.(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.Enter the 8 digit SIM unlock code
6.Select "OK". The handset is now successfully unlocked.
LG CU-515 Unlock Code Entry Instructions
1.Put a SP-locked sim in the phone, phone say invalid smart chip
2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Phone will be unlocked!
LG CU-575/TRAX Unlock Code Entry Instructions
Model : CU575 / Trax
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits
code
LG TU-720/CU-720/Shine Unlock Code Entry Instructions
Model : LG TU720 CU720 And All Shine SERIES
1) Power ON your phone with an accepted SIM card
2) Type *#865625#UNLOCK CODE
3) Press OK
4) Device is now unlocked
LG VU CU915 & CU920 Unlock Code Entry Instructions
1)Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2)Enter *#865625# then the 16 digit unlock code
3)Device should say: Network Lock Deactivated
4)Phone may automatically reboot
LG U8150 Unlock Code Entry Instructions
Model : LG U8150
1 - Switch ON your phone with a NOT Allowed SIM Card,
2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #,
3 - Go to menu "SIM Lock",
4 - Enter the Unlock Code we send to you.
LG KU990 ViewTV Unlock Code Entry Instructions
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3.Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
LG KE970 Shine Unlock Code Entry Instructions
all other LG KE970 Shine:
1.Switch ON your phone with an allowed SIM card
2.Then compose: 2945#*9701#
3. Press CALL.
4. It should you ask you for the code.
LG Unlock Code Entry Instructions - all other models
How to Enter Unlock Codes On LG Mobile Phones
Step Action
1 Insert non-Cingular SIM card
2 Power on the handset
- phone will display "phone restricted"
3 Select "Cancel"
- phone will display "phone restriction code"
4 Enter the SIM Unlock code
5 Select "OK"
or
Model : LG F2250
With orange sim card in the start menu tape : 2945#*3311# handset show saved then return to startup screen press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' tape your unlock code and OK.
Model : LG U8110
With a not allowed sim card in your phone enter Pin code then validate tape : 277634#*#, select 'Sim Unlock' menu enter NCK code then validate, your phone is now unlocked.
Model : LG U8210
With a not allowed sim card enter Pin code then validate tape : 277634#*#, now you show test menu choose Sim test menu and tape : 2945#*#, choose Sim Unlock menu, handset show 'Enter NCK' tape code Simlock, then OK.
Model : LG U8150
Switch ON your phone with a not allowed Sim card, compose : 277634#*# go to menu 'Sim Lock' and enter your unlock code.
Model : All Others
Switch ON your phone with an allowed sim card and compose :
2945#*5101# - LG 510w
1945#*5101# - LG 1200 & B1200
2945#*5221# - LG 5200 & 52200
2945#*5301# - LG 5300
2945#*5401# - LG 5400
2945#*70001# - LG 7020
2945#*7101# - LG 7100
2945#*1201# - LG 1100 & 1300
2945#*70001# - LG 7250T & 1100
2945#*2201# - LG C2200
2945#*5301# - LG T5100
2945#*3311# - C3310
Go to 'Menu' and then to 'Settings', select 'Security', to finish select 'Network Provider' and select 'Desactivate' then type your unlock code.
For the next models u must insert the original SIM:
LG C3100 press 2945#*3101#
LG C3380 press 2945#*7101#
LG F2300 press 2945#*7101#
LG KE260 press 2945#*2601#
LG KE970 press 2945#*9701#
LG KG120 press 2945#*1201#
LG KG220 press 2945#*1201#
LG KG240 press 2945#*3311#
LG KG280 press 2945#*7101#
LG KG290 press 2945#*7101#
LG KG800 press 2945#*7101#
LG KU250 press 2945#*250#
LG KU380 press 2945#*380#
After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK.
For next models insert a SIM (not the original SIM):
LG KU311 press 815118#*#
LG KU800 press 82652#*#
LG L600v press 815118#*#
LG U8150 press 277634#*#
LG U8210 press 277634#*#
LG U8500 press 277634#*#
Enter NCK and press OK.
Re: LG como poner el codigo subsidy
Mensaje  Nadeen el Miér Nov 17, 2010 1:03 pm
Buenas tarde quisiera liberar mi tlf LG ME770e es digitel lo quiero liberar como hago si alguien me puede ayudar sera de gran ayuda por favor existirá algún programa algún cogido
Nadeen
Invitado
Mensaje  Admin el Lun Nov 22, 2010 6:20 pm
si se puede por medio de tu imei, pero el costo es algo elevado, lo mejor seria que lo pudieras llevar con algun servicio en tu localidad, nosotros estamos en tampico tamaulipas, mexico, pero si gustas te podemos ayudar a liberarlo via imei , si te interesa mandame un email a movilesunlock@hotmail.com con los datos del equipo para enviarte el costo . gracias!
Mensaje  Contenido patrocinado
